Originally Posted By Polarapete
Originally Posted By fourgearsavoy
Leak down test before you disassemble it. At the very least do a compression check wet and dry.
Gus beer
I have a trick leak down tester that I have never used. Send me a PM and you can borrow it.
I plan on the leak down, checking the bearings on the rods and crank, I do have a leak down tester (thanks for the offer Pete)
going to check the roller lifters for anything out of the ordinary and replace the valve springs.
not sure what else to look for though
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
