ok, i'll keep the 108. the dist. is locked and the fuel curve is real straight at 13:1. i think the convertor also could be holding me back. its a PTC tight 9.5 with 4500 stall set up for street use. i go thru at 6000rpm, so a 4.30 gear may help also. thanks for the input.
