Maybe I haven't totally clear. I know how to combine a 518 with a 440 with the use of a Ultra Bell bellhousing or a JVXracing adapter kit.
I would like to know how to make de combination work.
A. using a controller, this would be an expensive option.
B. using a Transgo full manual shift kit and engaging the OD and lockup with a switch.
Because the fuel prices in Europe are very high I would like to use the 4th gear of a 518 and in this cae a 46RE.
Has anyone done this before?
The transgo full manual only changes the shifting it does NOTHING to the gov. circuit electronics , that is electronics .
