Leave the plug in. It reduces flow but a healthy clutch will live fine. The TF2 kit uses it to delay the high gear clutch so it doesn't come on with the K/D band (overlap, 2 gears at once). I use regular shop air 100psi. but I'm sure 30 will work as well.
Doug
