Originally Posted By preddy
So, what PSI do you other Edelbrock folks use for your fuel supply? I've heard that they are very sensitive to fuel pressure greater than 5.5 PSI.
I can't comment on the Edelbrocks as I have a fine collection of Carter AFBs I tinker with but I don't even bother running a regulator. The Duster just runs an electric self-regulated pump and the GTX runs an electric feeding a Carter race mechanical. When I was running the 6-pack hood with a fuel gauge I'd see as high as 12 psi which never seems to bother it.
"I think its got a hemi"
