Just run a wire from starter relay to ground, or get a pre '70 manual trans starter relay for the cleanest look. My '08 JK Wrangler has a clutch switch and I'm glad for it. And I never had an issue with the T. O. Bearing on my Bee with the clutch switch so will be reinstalling it just because it's supposed to be there. If you're not using the reverse lockout, just pull it into neutral before putting in the key.
It's not the throwout bearing that it's an issue with, it's the thrust bearing in the engine.
