It's a 625 AFB, electric choke. There is a check ball and weight in the passage leading to the pump discharge nozzles and it's clear of debris. The one you have pictured looks like one of my jets , I don't recall seeing that type in mine. I am going in again once parts arrive in mai
It is in the bottom of the driver side fuel bowl.Goes into the pump well on an angle.The ball is spring loaded.When the pump is raised it draws fuel from the bowl to the pump well.When pump is in down stroke the ball is seated and fuel then goes to the discharge nozzle.If there is debris in it you will get the condition you have as some of the fuel will leak past and go back into the bowl.
