Quote: I was going to suggest some waded newspaper, or perhaps doing the repair correctly using and old street sign to fill the hole?....I don't know why he's using spraycans?.....a paint roller works just fine, maybe even blot it on with a paint sponge from HomeDepot.......perhaps you use this technique too?.......hence the need for
When the fixed the Levey that broke in new orleans they stuffed the cracks with newspaper at the expantion joints and then spread some sealer on it! Since they were out of what they were supossed to use
