Thanks AHY I will find out what the thread is. Someone told me a banjo won't work, do you think that is the case?
Thanks BBM - I tested it with the steering linkage connected. I also threw a tire on it and tried it but I admit I didn't have a tire on the other side. The bleed screw is at the top on the outside so I think it is fine.
