I use longer studs and spacers for this exact problem, but I have also taken the rotor off, taken the lug studs out, put it on a lathe, and cut 1/8 inch off the center hub. I have your same rotors and this works great, I can take a better pic if it would help. I also had to switch to these "raised" center caps...
This is what I did. I wasn't about to [censored] up a new set of wheels.
