I use type f Walmart in my dragster--works like a dream and I can afford to change it more often--I like the Napa type F but prices have just gone up and up on it--Walmart for me!
Trick fluid never offered any advantage that I could point to except on paper. If you use a trans brake hard with big HP then I am guessing a synthetic will give you more protection against the heat breakdown--or...just us Walmart and change it out when needed.
