this was on 2 different 340's. maybe the 360 cap is a different height but I am SURE i punched a hole thru 1 pan 10 years age and learned I needed the countersunk philips then.
then on my 416 build this summer, I had the same problem. I needed to grind the edge of the pump ever so slightly and dent the bottom of the pan.
