There is just somthing about a blanket that make's me feel more secure, but it has to also cover the flywheel/converter area, let's hear some opinion's why you like your choice better.
The possibility of an explosion is why you also use a bolt in sprag, a low band apply valve body AND a BILLET front drum. I prefer the blanket AFTER I installed all the aforementioned parts. Fits better, and easier to install/remove. A GOOD engine builder and a washing machine takes care of the oil issue.
Karma has no menu. You get served what you deserve.
