Re: which one do you guy's preferr,tranny blanket or shield
[Re: blownzoom440]
#188895
01/09/09 11:43 PM
01/09/09 11:43 PM
Posts: 34,952 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Blankets hold heat,cause premature wear
Blankets get all cruddy /dirty easy
Blankets don't cover enough area
Blankets are hard to get the straps from dragging on the ground
Blankets burn up on headers easy
Thats just a few reasons, My sheild was a KIND of hard to get to fit though
Some seem to be able to get them on easy mine , no bueno
1)use the proper trans cooler. 2)both wil get cruddy/dirty 3)just need a full coverage blanket! 4)you can cut or tuck straps out of the way. 5)i use header wrap.salution is dependent on aplication of vehicle. 6)that is what you get for buying a shield.
Hmmm .. well, do you use a down comforter in the summer time on your bed ? You have air in house I would guess right ?
shields do not get dirty, sopped with fluid, dirt One quick rinse with brake cleaner its right back to like new condition, try that with a blanket
since when do they make a blanket that covers the bellhousing area ?
Sure cut the straps off , next time you try to install it , get it right back to the same spot so they fit .. good one
Sure , use header wrap, good idea, hold heat in headers and dirt, etc and then they are shot too
Mine did not fit the tunnel because I moved my motor back or it would have
Done with the topic , not going to argue
look at 99% of super gas or super comp cars
No one runs blankets that I've seen
That my two cents . moving on
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Entire Thread
dartman366
01/10/09 01:41 AM
blownzoom440
01/10/09 02:00 AM
bigdad
01/10/09 02:45 AM
dartman366
01/10/09 02:47 AM
bigdad
01/10/09 02:56 AM
dartman366
01/10/09 03:11 AM
MR_P_BODY
01/10/09 03:24 AM
bigdad
01/10/09 03:26 AM
J_BODY
01/10/09 05:15 AM
bigdad
01/10/09 05:20 AM
bigdad
01/10/09 05:24 AM
340RICK
01/10/09 11:42 AM
J_BODY
01/10/09 02:55 PM
Chad Bittle
01/10/09 06:07 PM
hemidup
01/10/09 03:15 AM
blownzoom440
01/10/09 03:31 AM
bigdad
01/10/09 03:43 AM
blownzoom440
01/10/09 03:47 AM
SKR8PN
01/10/09 04:32 AM
