mine has been run from 2002.after 3yrs i checked the bearings and caps[stock iron w/studs]there was signs of walk.the cheepest,least invasive improvement was a girdle from gearsandrears[chenoweth] so i have been using that and will check the bearings next yr 2010.i cant realy explain why,whynots.i just hope it last.
