Also you can spray new paint directly over the old paint. Sand the old stuff smooth, feathering it all together and spray it with a single stage acrylic urethane black paint and you're done. You'll have to burn off the last of what's left of the old clear coat, but you won't need to prime it. If anything, spot prime some areas with a rattle can.
