THERE ARE NO WARRANTIES, EXPRESSED OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF
MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, WHICH
EXTEND BEYOND THE DESCRIPTION ON THE FACE HEREOF. ANY IMPLIED WARRANTIES ARE DISCLAIMED TO
THE FULLEST EXTENT PERMITTED BY LAW. THIS WARRANTY DOES NOT COVER CONSEQUENTIAL DAMAGES,
LOSS OF TIME OR REVENUES, INCONVENIENCE, LOSS OF USE OF THE VEHICLE, DAMAGE TO THE VEHICLE OR
COMPONENTS OF THE VEHICLE, ANY OTHER TYPE OF CONSEQUENTIAL DAMAGES, OR OTHER INCIDENTAL
OR INDIRECT DAMAGES. HOTCHKIS’ MAXIMUM LIABILITY UNDER THIS WARRANTY SHALL IN NO EVENT
EXCEED THE PURCHASE PRICE OF THE PRODUCT. Some states do not allow limitations on how long an
implied warranty lasts or the exclusion or limitation of incidental or consequential damages and in such
states the above limitations or exclusions may not apply. This limited warranty gives the purchaser
specific legal rights and the purchaser may have other rights that may vary from state to state.
Technical Information
Hotchkis Performance makes every effort to ensure that you are provided with the most accurate and
up-to-date technical information. However, all technical information is approximate and may vary
upon application. Additional suspension components may be needed in some applications, depending
upon the make, model, engine and chassis of the vehicle. Hotchkis Performance is not responsible for
any consequences resulting from manufacturer’s technical mid-year changes. Hotchkis Performance
products should only be installed by a qualified, licensed auto mechanic experienced in the installation
of such products.
Warranty Claim Procedure:
The answer to ALL the following questions should be YES before making a warranty claim:
Is the product appropriate to your application?
Did you carefully and thoroughly read the instructions provided along with the product?
Do you have the original invoice or sales receipt?
Is the return date within 36 months from the purchase date?
Are you the original purchaser?
Was the product properly installed by a qualified, licensed auto mechanic?
Has the product been installed on the original vehicle on which it was installed at all times?
Is the product unmodified and clean?
Is the reason for return a legitimate product defect?
If the answer to all these questions is YES, please contact our Customer Service Department at (562) 907-
7757. You will be given a Returned Goods Authorization Number (RGA) valid for 60 days. You will also be
asked to ship the product prepaid to our facility. All shipments MUST be (i) prepaid, (ii) include the
original invoice or sales receipt, (iii) show the RGA on the outside of the package and (iv) include your
name, address, make and model of the vehicle, and a brief description of the claimed defect,
including the circumstances under which the defect occurred. Warranty related inquires should be
sent to the following address:
HOTCHKIS PERFORMANCE, LLC
C/O CUSTOMER SERVICE
12035 BURKE ST. SUITE 13
SANTA FE SPRINGS, CA 90670
Hotchkis Performance will not accept product returns without the RGA number, receipt and the
information described above. C.O.D. or collect shipments will be refused. Once the returns are received
at Hotchkis Performance, we will evaluate the products, verify the sales receipt, and investigate the
warranty claim.
