Our arms are the only ones on the market that correct all of the deficiencies in the factory suspension and are designed to work with modern spring and shock rates as well as tires. Our suspension is on the fastest Mopars across the country! We'll have the the EMax at the Carlisle Chrysler Show in July to prove it!
Dan, can you elaborate a tad on the factory deficiencies that have been remedied?
Camber change, bump steer, compliance, etc? I noticed you have extra bracketry with your arms but would like a little detail on how those are benefitting the system.
