I have an aluminum drum in mine, and maybe the tangs on the drum are not as deep. But here is a pic of how it fits. I would wonder about yours as well.
It is too late now, but I always check the endplay before taking the trans apart. Then compare that to after you put it together. Unless you change parts (selective thrust washer thickness, etc) it should be close. Remember, changing the gear train parts shouldn't effect it since the input end play is the input section (shaft, clutch hub) pressing againts the small thrust washer on the front of the output shaft.
If you didn't get the last clutch disc engaged, it would be off by 0.060"-0.095"
Thanks for the advice Jim. Mine also has an aluminum drum and I mostly questioned it's engaugement because my drive tangs do not fully engauge. From your picture, your drive tangs do at least come flush with the shell. I will go out this morning and do some checking on mine.
