Originally Posted By Streetwize
Can somebody respond to my question of the benefits of square jetting/blocking the PV in terms of throttle response/consistency for a 3000 rpm/stutter 2-step launch on a 5000 stall converter. Am I likely to see any real difference (60' et improvement) since I'm essentially shooting off the rear pump shot anyway? I mean it seems logical to me (take the potential PV "flutter" out of the equation and truly equalize the A/F ratio from F/R) but want to get my head around the real reasoning or something I'm not considering. I know it's easy enough to try but before I do I want to hear other opinions....thanks!
The 1000HP 4150 carb was originally on a 508" street driven Big block where the PV was beneficial for cruising.
As I stated, I got a stronger signal and instantly better idle and throttle response, almost like it had a small vacuum leak, but I never found one and yet I checked many times. I do not trust the PV delivers fuel evenly with a nasty cam. With a street car, its probably a lot better, but when you have real duration and a real lack of vacuum signal I think its best to get rid of it. I have the best idle on this thing and yet my duration at 50 is over 300......
I run this carb on my 512 and the jetting and air bleeds posted above flat out works. I trap 110-111mph in the 1/8th with this thing. The way he sent it did not. And it took a while to sort it out, but its about as good as I think it will get and I want to focus on the SV1 a little.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
