Originally Posted By autoxcuda
This was a weird one.
Might be been from old age or just a fluke. But someone pointed out chroming can make the steel brittle. Running at speed put a lot more vibrations and stress on about everything.
Evan had the can on his power steering come off right above where it's soldered/fusion welded/?? on. The weld didn't fail if you look closely, it was the metal right above the weld.
We were talking with him on Saturday at the show and thought it might have been due to not running a PS cooler, so the hot fluid expanded and had nowhere to go.
