Originally Posted By 72Swinger
Originally Posted By autoxcuda
This was a weird one.
Might be been from old age or just a fluke. But someone pointed out chroming can make the steel brittle. Running at speed put a lot more vibrations and stress on about everything.
Evan had the can on his power steering come off right above where it's soldered/fusion welded/?? on. The weld didn't fail if you look closely, it was the metal right above the weld.
That is day ender stuff there, daaaang.
It was in the afternoon. So only a couple hours left at most.
Evan got the long distance award!
