Thats very easy for you to say.Have you ever had a exhaust leak???It drives you crazy.If you want to be that way and assemble and reassenble your manifolds and exhaust,go ahead,for me I put gaskets(remflex and forget about it.Also he is talking about the manifold to EXHAUST,not head.
I make sure all mating surfaces are flat and no leaks. No gaskets on either mating surfage as I stated befor.
