If you are using the stock exhaust manifolds, then no gasket is required. All Mopars with stock exhaust manifolds were put on with out gaskets and thus were only metal to metal. Check the surface facing on the manifolds and the heads and if need be a slight swipe of the surfaces will true them up. But get rid of the gaskets as they are not needed....
