There are particular gear sets than will be noisy, no matter the set-up. But that is more brand or batch specific, than ratio specific.
I agree with this. Most gears will not make much noise if set-up right. But I have seen some that make noise (not alot of noise but some) and they were done by good shops. Working for a Dodge dealer I can tell you I remember a truck that a customer complained the rear was noisey. It was a brand new truck with the new to Dodge "American Rear" and this was around 2005 to 2008 as I dont remember which year. I ended up replacing the ring and pinion and the pinion and carrier bearings as per the Mopar tech adviser and it was no different when I was done. And we had the proper tools for it since we were a Dodge dealer. It was not alot of noise as it was a small whine at about 55 mph. In fact most people would not even complain but this guy must have drove this speed alot. So in the long run Mopar had me replace the full drum to drum rear and recheck all the settings including pinion angle which made no difference as it still had some noise. I do believe the whine noise in the complete new unit did happen at a slightly lower speed. In the end the custumer was told that small whine is normal as it was and as I said most people like you all and me would have never even thought it was noisey enough to complain about. The guy took the truck happy with us as he saw me replacing the complete unit because the service manager brought him in the shop so he could see for himself we replaced the drum to drum unit. Ron
They had to do this with my 03 Ram with the 9.25 SG. They rebuilt the original one with all new stuff and it still was noisy. It sounds like it was similar noise wise to yours and had the dealer not jerked me around on some other issues I would likely never have put in a claim, but...
So they dialed the case and found it was out of spec and ordered a new housing and filled it up with new parts. When I asked why they didn't just install a drop in complete unit, I was told that a drum to drum 9.25 wasn't available and they had to build them at the dealer from scratch. Sounded like a fairy tale to me but either way I had a new diff under my truck.
Of course they still managed to get into my wallet for a few hundred because the parking brake shoes were FUBAR and not covered under warranty. $125 a set for the shoes plus brake job labor now because that's a separate repair. I hate dealerships...
But the diff in mine is now silent.
Kevin
