I was reading on the Hotchkis site about shims to correct midline alignment between the front and rear wheels ( thrust alignment) by shimming the rear leaf spring mount. They talk about using an alignment shop to measure and determine if there is a misalignment. How can we do this accurately at home? I think I may have this issue as my car (Cuda) does not want to launch straight under heavy acceleration. Thanks!
