Dave - Best thing to do is to find one of the frame measurement holes that is symmetrical left to right. I do a cross measurement from the hole in the frame to the center bolt of the leaf spring. That will give you a good idea of what is going on in the rear. Usually, the pass side needs a shim or two. I make them in 1/8".
