Quote: Just put a Racepak Sportsman in the car this winter.... I've got ALOT to learn! Cool seeing how high the converter flashes after tbrake release. Seeing actual shift rpm in relation to your shift light..... and noting how long my 1-2 shift was takng in relation to my 2-3..... Self inflicted hydraulic leak was slipping the band. Eventually I want to add oil psi, coolant temp, and one O2 sensor at least. I bought mine used at a lil savings...
When it comes to temps they use the standard K-type probes.. a 1/4" K-probe will work great.. just gonna need to weld a boss onto the radiator then use a 1/4" compression to 1/4" pipe fitting... you can look on line to find K-probes pretty cheap
