with the wiplash cam do u have to cut the valve guides down?
stock guides are good up to .520" lift before you will smack the guide top.
Edit with more info; stock valve springs and retainers are only good to .520" lift. Hughes springs and retainers package for magnum heads will give anoth ".100" of lift allowance on stock magnum heads.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
