That combo got me 285 rwhp 325 rwtq
Started as stock 5.9. Swapped to a thinner head gasket, added the whiplash cam, and since it was an EFI truck, I added a 2bbl M1 intake, cheap mid-length headers, and reprogrammed the stock EFI computer with SCT. Even had the stock restrictive throttle body and those nasty cracked stock heads.
You should have the same results with a 750 CFM carb, a nice dual plane intake, and headers.
**Photobucket sucks**
