This is the first time I saw a video also. I was too low rpm off the 2 step. Everything looks stiff. No rise front or rear.
Converter was good for a 1.405 with Caltracs and leafs, normally 1.450. 8" PTC built from dyno sheets.
Front is Bob's profab with single adjustable QA1 set all the way to minus.
Rear is QA1 double adjustable with "R" (rebound) set all the way to minus.
If minus is not loose, I guess I'm bassackwards on the shocks.
