While you have the housings apart (clear lens removed) you install the projector assembly, install the whole housing back in the car and rotate the projector until it is level. Remove the housings, seal the clear outer lens back on and then re-install the complete housing and adjust as normal for height. Time consuming but worth the effort.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
