Quote: Somebody should come up w/ some type of formula that takes into account car weight, engine HP & torque, 60-ft, ET, MPH, etc., to be able to define a factor to use in comparing these.
I have a formula.........when it breaks, you have gone too far with weight and or power............LOL!!!
then you can buy a new tranny to boot....
That ISNT FACT... when I blew the stock 8 3/4 I pulled the trans to make sure.. it was fine.. still running the same trans and the same sprag
it is fact I can show you the pieces
You act like EVERY one will blow the sprag... NOT.. and I have a trans that says so
