Hello gentleman, I am knee deep in thought, wracking my brain to make an 833 function behind a magnum 5.9 with factory injection. So now I am thinking maybe the bellhousing out of a pre-magnum truck. I can't find any info... Checking Rockauto, it shows a 79 Ramcharger as using an 11" clutch. Would that be a 143 tooth flywheel? If so logic would say, a truck/Ramcharger bellhousing would work? Thanks
