Just go on e-bay and buy one for a BB mopar. It will work. I gave my last complete set away or I'd give you a deal. The cable will be more of a hassle. You should be fine. You only get into trouble when you use a high rise intake. I had a 440 w/ RPM, 1/2 spacer and Holley 750 and used the stock 440 unit.
