Quote: I bought a truck that had a Lokar throttle cable. I almost wrecked it on the way home do to a stuck throttle. The cable had sawed though the sleeve and was binding up. I put an OEM cable back on.
Rather than fight getting a solid kick down linkage to clear headers, I installed a Bouchillon KD kit on my '68 V100. It is heavy duty compared to Lokar and has the correct carb linkage to KD lever ratio.
They have multiple options for sleeve material, do you remember which type you had? Does the bouchillon kit work on edelbrock carbs and manifolds?
