I used this one on my camper and it works well. Just make sure it is set up properly or it won`t work like it is intended. http://www.etrailer.com/Weight-Distribution/Reese/RP66074.html
and make sure you have a minimum of 10% of the GTW at the point of trailer to tow vehicle connection.
This is a MAJOR point.. 10% minimum and no more than 15% on the tongue and proper sized bars for the load EDIT Make sure the whole rig is level with the loading hitch... in MOST cases that means the top of the ball is at 19" above the ground
Tried to get that out of him with my question too, but, he chooses to ignore someone with experience.
Mo' Farts
Moderated by "tbagger".
