(1) no air (2) only the L/R front corner assys were changed. (3) same pads (4) I'd brake kleen the pads/calipers (5 grab helper for the pedal (6) visual as he works the pedal (7) compare the old rotor(s) finish to the new rotor(s) finish (tho I dont think that if they are clean) (8) all that is left is a caliper piston travel problem from the retraction (mighta messed up the square seals) but both (L/R corners) appear to be fubared as it ain't pulling to one particular side.
unless the retracting messed up both of em. Andrew holler how it turns out
