Purchased a keissler 5sp years ago. Finally getting towards the end of my first and last restoration. My question is do I need to use the spring on the clutch pedal since it is a hydraulic clutch. Nothing in the install instructions says anything about having to use the spring.I assume the hydraulic pressure keeps the pedal up. Thanks.
Lose the spring but be careful to not lose some teeth at the same time. My factory Viper TOB has a spring that keeps it on the fingers at all times.
Mopar to the bone!!!
