I think you're probably correct in thinking that the hydraulic throw out bearing will retract enough to keep it off the clutch fingers. If not then you'll have to find some way to keep it from riding on the clutch fingers. Good luck.
FYI... the hyd throw out bearing supplied by Keisler (FTE manufactured) is actually intended to have a predetermined pre-load on the clutch fingers regardless of cover style, the TOB is designed to withstand substained engine RPM in a constant state, unlike a factory OEM TOB....
Mike
