you used Magnum heads? I'll have to look into the 270H vs the 260H.
I want as LITTLE interference issues as possible valve to piston, retainer to guide etc while still waking this motor up a bit from stock. I don't see this motor ever seeing 4500 on the tach, being in a truck.
