Re: Vacume pump users, do you see water vapor?
[Re: MRMOPAR622]
#1724402
01/08/15 01:03 PM
01/08/15 01:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When you drain your vacuum tank you will also find a small amount of water the 1st time and this is normal.On an alcohol engine you will find even more water.
Sure.. alky engines(fuel) absorbs water so when its heated it separates... same with E-85.. so you have 2 sources of moisture being carried into the engine
Entire Thread
Cab_Burge
01/08/15 02:49 AM
MR_P_BODY
01/08/15 02:55 AM
9secondsatellite
01/08/15 03:18 AM
Ohio Joe
01/08/15 03:22 AM
DJVCuda
01/08/15 03:26 AM
dvw
01/08/15 04:38 AM
1967dartgt
01/08/15 04:57 AM
rebel
01/08/15 06:19 AM
Leon441
01/08/15 11:42 AM
an8sec70cuda
01/08/15 03:00 PM
Forest
01/08/15 04:12 PM
9secondsatellite
01/08/15 10:13 PM
MR_P_BODY
01/08/15 10:18 PM
Forest
01/08/15 11:43 PM
MR_P_BODY
01/08/15 11:47 PM
Cab_Burge
01/17/15 09:47 PM
MR_P_BODY
01/17/15 10:08 PM
Cab_Burge
01/18/15 05:33 AM
cudadon
01/11/15 11:45 PM
Forest
01/18/15 05:49 AM
slippery440
01/08/15 04:13 PM
MR_P_BODY
01/08/15 04:18 PM
MRMOPAR622
01/08/15 04:43 PM
MR_P_BODY
01/08/15 04:53 PM
MRMOPAR622
01/08/15 04:58 PM
MR_P_BODY
01/08/15 05:03 PM
Oyvind Mopar
01/08/15 06:27 PM
