My 98 1500 keeps throwing a code for the output speed sensor. I have changed the one in the rear end housing, cleaned it out and put fresh gear lube in it. Still puts the check engine light on. Any ideas? ) I should mention the speedo is working fine. Truck has about 150 k miles.
