I'm going to use the Lunati 60312 hydraulic roller. The 60313 is too big and don't want to overcam.
Specs:
RPM: 2200 - 6200
Lift: .535"/.550"
Duration @.050": 231/239
Duration: 282/290
Lobe sep: 110
I'm leaning towards either 440 Source or Muscle Motors. I like that they use -26.7cc dome pistons. I can get a near perfect compression ratio and quench for what I want out of it for a street motor with aluminum heads.
I don't like that Muscle Motors uses either K1 or RPM cranks, read good things about K1 but haven't read much at all about RPM. Would want to make sure I got a K1 crank. They also only use RPM rods which I don't know anything about.
