Quote: I need to find a set up for my tunnel ram that will fit under a 7 inch tall hood scoop.
If you go to K&Ns web site they have many different shapes of filters. You may have to get creative to build the base, but lids are easy to make out of aluminum plate should you need every last bit of room. For my race motor with a Dominater flange I used a drop base attached to an air pan combined with a 14x6 and a flat lid to get it under my scoop.
