Simply put, if you wanna run an air filter, find the biggest one that will fit your application. If your car runs better with one, you have turbulence / A/F mixture issues or the carb is too big - all of which should be corrected by other means than installing an air filter. No matter how you cut it, an air filter is a restriction.
