I always put the pan on last - just in case I drop something in the motor !!
That said, I've never seen the need to re-adjust the position of the block - hell, a short block isn't THAT hard to spin. I mount the block with the cam tunnel as close to the pivot centerline as possible. The bottom end will be heavier till the top end goes on, then its a pretty good balance.
