The bonzi 8.80 ET is still short of 1100 HP. Once again HOW many passes were put on this combo? And how many were in the 8.80 range? I've gone 8.60's-8.80's with a stock non-filled no girdle engine at a MUCH lower weight and the block was cracked after 275 passes and was still running 8.60's before I took it apart for rebuild. Mine were also with the weaker 440 (RB) block.
Wallace calculator puts 155 mph at 3700 Lbs as 1103 HP. 145 and 3700 Lbs calcs 903.
Kevin
