I don't think a motor with 820 passes on it needs crossbolted mains or a girdle !!!
820 passes @ 6000 rpm is nothing...
The 820 passes, nor the rpm has anything to do with it. All that matters is the power level. This motor obviously doesn't make much of that, so the cap issue is really a non issue.
Monte
that combo will probably last for ever
