New up Dates are, the Willwood brakes are on these way
Also ordered a atomic efi that also shipped and a new hood. He hod is a fiberglass piece that has a 70 amx scoop
The gas tank is being restored since it's full of crud I am about to pull the front suspension apart and install the poly bushings also. Soils should be ready for a good cleaning of its underside and then off o paint
